[mapserver-users] WFS Client through Proxy and HTTP Authentication
bteluk at gmail.com bteluk at gmail.com
Tue Aug 9 21:10:51 EDT 2011
I have MapServer 5.6.0 running on RHEL5.5 (FGS9.5 MapServer package)
I'm behind a proxy (NTLM), and I want to access a WFS source outside that
requires HTTP Authentication.  I'm using a WFS Client setup in my Map file,
and I'm accessing my MapServer using WFS too - eg. a WFS Client... all up a
sort of WFS Relay.
I can do it fine with WMS, however, I can't get it to work with WFS - is it
actually supposed to work?  (not documented in the manual.)  I tried using
"ows_" prefixed METADATA which works fine with WMS (to the same service.)
Here's my map file extract:
LAYER
  NAME "TempDryBulb"
  TYPE RASTER
  STATUS ON
  DEBUG ON
  CONNECTIONTYPE WMS
  CONNECTION "http://reg.bom.gov.au/cgi-bin/reg/ws/gis/users/bomg0022/wxs?"
  METADATA
    # Source Data
    "wfs_connectiontimeout" "30"
    "wfs_maxfeatures" "10"
    "wfs_typename" "IDY03103_dryblb"
    "wfs_version" "1.0.0"
    "wfs_srs" "EPSG:4283"
    # Source Auth
    "ows_auth_username" "mybomuser"
    "ows_auth_password" "{secrethere}"
    "ows_auth_type" "basic"
    # EDN Proxy Auth
    "ows_proxy_auth_type" "ntlm"
    "ows_proxy_host" "httpgw.mycompany.com.au"
    "ows_proxy_port" "8080"
    "ows_proxy_type" "http"
    "ows_proxy_username" "myuser"
    "ows_proxy_password" "{secrethere}"
    # Layer Outgoing Metadata
    "wfs_title" "TempDryBulbWFS"
  END # METADATA
Here's my errors:
[Tue Aug  9 14:01:18 2011].368922 HTTP: Starting to prepare HTTP requests.
[Tue Aug  9 14:01:18 2011].369001 Using
CURL_CA_BUNDLE=/home/maptools/fgs/share/curl/cacert.pem
[Tue Aug  9 14:01:18 2011].369101 HTTP request: id=0,
[Tue Aug  9 14:01:18 2011].369260 HTTP: Before download loop
[Tue Aug  9 14:01:18 2011].373358 HTTP: After download loop
[Tue Aug  9 14:01:18 2011].373370 msHTTPExecuteRequests() timing summary per
layer (connect_time + time_to_first_packet + download_time = total_time in
seconds)
[Tue Aug  9 14:01:18 2011].373378 HTTP: request failed with curl error code
6 (Couldn't resolve host 'reg.bom.gov.au') for
http://reg.bom.gov.au/cgi-bin/reg/ws/gis/users/bomg0022/wxs?[Tue Aug  9
14:01:18 2011].373387 msHTTPExecuteRequests(): HTTP request error. HTTP:
request failed with curl error code 6 (Couldn't resolve host
[Tue Aug  9 14:01:18 2011].373414 Layer 0: 0.000 + 0.000 + 0.000 = 0.000s
[Tue Aug  9 14:01:18 2011].373584 msWFSLayerWhichShapes(): WFS connection
error. Got HTTP status -6 downloading WFS layer TempDryBulbWFS
[Tue Aug  9 14:01:18 2011].374109 msWFSLayerWhichShapes(): WFS connection
[Tue Aug  9 14:01:18 2011].374124 msWFSGetFeature(): WFS server error.
ms_error->code not found
Note: I used msencrypt for the passwords, and these did work fine for WMS.
Note2: using wget or curl from the command line on the server works fine
(with the proxy credentials specified.)
Thanks in advance!
Regards, Bill Teluk
Regards, Bill Teluk
View this message in context: http://osgeo-org.1803224.n2.nabble.com/WFS-Client-through-Proxy-and-HTTP-Authentication-tp6670451p6670451.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
