[mapserver-users] WFS Client through Proxy and HTTP Authentication
Daniel Morissette
dmorissette at mapgears.com
Tue Aug 9 21:49:46 EDT 2011
The error message says:
"Couldn't resolve host 'reg.bom.gov.au'"
Make sure this hostname does resolve on the machine running MapServer,
that is has proper DNS config, etc.
You could also try using the actual IP address instead of the hostname
in the CONNECTION string to confirm that this is indeed the problem.
Daniel
On 11-08-09 09:10 PM, bteluk at gmail.com wrote:
> Hi,
> I have MapServer 5.6.0 running on RHEL5.5 (FGS9.5 MapServer package)
> I'm behind a proxy (NTLM), and I want to access a WFS source outside that
> requires HTTP Authentication. I'm using a WFS Client setup in my Map file,
> and I'm accessing my MapServer using WFS too - eg. a WFS Client... all up a
> sort of WFS Relay.
> I can do it fine with WMS, however, I can't get it to work with WFS - is it
> actually supposed to work? (not documented in the manual.) I tried using
> "ows_" prefixed METADATA which works fine with WMS (to the same service.)
> Here's my map file extract:
> LAYER
> NAME "TempDryBulb"
> TYPE RASTER
> STATUS ON
> DEBUG ON
> CONNECTIONTYPE WMS
> CONNECTION "http://reg.bom.gov.au/cgi-bin/reg/ws/gis/users/bomg0022/wxs?"
> METADATA
> # Source Data
> "wfs_connectiontimeout" "30"
> "wfs_maxfeatures" "10"
> "wfs_typename" "IDY03103_dryblb"
> "wfs_version" "1.0.0"
> "wfs_srs" "EPSG:4283"
> # Source Auth
> "ows_auth_username" "mybomuser"
> "ows_auth_password" "{secrethere}"
> "ows_auth_type" "basic"
> # EDN Proxy Auth
> "ows_proxy_auth_type" "ntlm"
> "ows_proxy_host" "httpgw.mycompany.com.au"
> "ows_proxy_port" "8080"
> "ows_proxy_type" "http"
> "ows_proxy_username" "myuser"
> "ows_proxy_password" "{secrethere}"
> # Layer Outgoing Metadata
> "wfs_title" "TempDryBulbWFS"
> END # METADATA
> Here's my errors:
> [Tue Aug 9 14:01:18 2011].368922 HTTP: Starting to prepare HTTP requests.
> [Tue Aug 9 14:01:18 2011].369001 Using
> CURL_CA_BUNDLE=/home/maptools/fgs/share/curl/cacert.pem
> [Tue Aug 9 14:01:18 2011].369101 HTTP request: id=0,
> [Tue Aug 9 14:01:18 2011].369260 HTTP: Before download loop
> [Tue Aug 9 14:01:18 2011].373358 HTTP: After download loop
> [Tue Aug 9 14:01:18 2011].373370 msHTTPExecuteRequests() timing summary per
> layer (connect_time + time_to_first_packet + download_time = total_time in
> seconds)
> [Tue Aug 9 14:01:18 2011].373378 HTTP: request failed with curl error code
> 6 (Couldn't resolve host 'reg.bom.gov.au') for
> http://reg.bom.gov.au/cgi-bin/reg/ws/gis/users/bomg0022/wxs?[Tue Aug 9
> 14:01:18 2011].373387 msHTTPExecuteRequests(): HTTP request error. HTTP:
> request failed with curl error code 6 (Couldn't resolve host
> [Tue Aug 9 14:01:18 2011].373414 Layer 0: 0.000 + 0.000 + 0.000 = 0.000s
> [Tue Aug 9 14:01:18 2011].373584 msWFSLayerWhichShapes(): WFS connection
> error. Got HTTP status -6 downloading WFS layer TempDryBulbWFS
> [Tue Aug 9 14:01:18 2011].374109 msWFSLayerWhichShapes(): WFS connection
> [Tue Aug 9 14:01:18 2011].374124 msWFSGetFeature(): WFS server error.
> ms_error->code not found
> Note: I used msencrypt for the passwords, and these did work fine for WMS.
> Note2: using wget or curl from the command line on the server works fine
> (with the proxy credentials specified.)
> Thanks in advance!
> Regards, Bill Teluk
> Regards, Bill Teluk
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/WFS-Client-through-Proxy-and-HTTP-Authentication-tp6670451p6670451.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
