[mapserver-users] Re: mapserver-users Digest, Vol 43, Issue 50
Sila Khan
silasharmeen at gmail.com
Thu Aug 25 02:41:23 EDT 2011
i want to load grib file in in browser and openlayers through mapfile .
this is my mapfile
MAP
NAME "MAP"
# Map image size
SIZE 300 200
UNITS meters
CONFIG "MS_ERRORFILE" "/ms4w/Apache/logs.log"
DEBUG 5
EXTENT -9.000000 -110.772277 369.000000 109.772277
#FONTSET '../etc/fonts.txt'
#SYMBOLSET '../etc/symbols.sym'
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
# Background color for the map canvas -- change as desired
IMAGECOLOR 255 255 255
IMAGEQUALITY 95
IMAGETYPE png
OUTPUTFORMAT
NAME png
DRIVER 'GD/PNG'
MIMETYPE 'image/png'
IMAGEMODE RGBA
EXTENSION 'png'
END
# Legend
LEGEND
STATUS ON
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
END
# Web interface definition. Only the template parameter
# is required to display a map. See MapServer documentation
WEB
# Set IMAGEPATH to the path where MapServer should
# write its output.
#IMAGEPATH '/tmp/ms_tmp/'
# Set IMAGEURL to the url that points to IMAGEPATH
# as defined in your web server configuration
#IMAGEURL '/ms_tmp/'
IMAGEPATH 'output/'
IMAGEURL 'output/'
LOG "/tmp/gmap.log"
# WMS server settings
METADATA
'ows_title' 'MAP'
'ows_onlineresource' '
http://localhost/cgi-bin/mapserv?map=C:/ms4w/Apache/htdocs/shapefiles/GRIB_DATA/grib.map
'ows_srs' 'EPSG:4326'
END
#Scale range at which web interface will operate
# Template and header/footer settings
# Only the template parameter is required to display a map. See
TEMPLATE 'templates/grib.html'
END
LAYER
NAME 'gfs.t00z.pgrbf03'
TYPE RASTER
DUMP true
TEMPLATE fooOnlyForWMSGetFeatureInfo
#DATA 'C:/ms4w/Apache/htdocs/shapefiles/GRIB_DATA/gfs.t00z.pgrbf03'
DATA 'C:/ms4w/Apache/htdocs/shapefiles/GRIB_DATA/55'
METADATA
'ows_title' 'gfs.t00z.pgrbf03'
'ows_title' '55'
END
STATUS OFF
TRANSPARENCY 10
PROJECTION
'proj=longlat'
'ellps=WGS84'
'datum=WGS84'
'no_defs'
END
PROCESSING 'BANDS=1'
CLASS
NAME 'red'
EXPRESSION ([pixel] < -3)
STYLE
COLOR 255 0 0
END
END
CLASS
NAME 'green'
EXPRESSION ([pixel] >= -3 and [pixel] < 3)
STYLE
COLOR 0 255 0
END
END
CLASS
NAME 'blue'
EXPRESSION ([pixel] >= 3)
STYLE
COLOR 0 0 255
END
END
END
and i put the url in browser as
http://localhost/cgi-bin/mapserv.exe?map=/ms4w/Apache/htdocs/shapefiles/GRIB_DATA/grib.map&LAYERS=gfs.t00z.pgrbf03&FORMAT=png&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG:4326&BBOX=-9.000000%20-110.772277%20369.000000%20109.772277&WIDTH=500&HEIGHT=500
it throws the ERROR
msWMSLoadGetMapParms():WMS server error.wrong number of arguments for BBOX
plz help me to find where i m doing wrong in mapfile or in url
Thanks Regards
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110825/8adc6c00/attachment-0001.html
