[mapserver-users] Re: Mapserver 6.0.1 -- Label Class not recognizing token BACKGROUNDCOLOR
thomas bonfort thomas.bonfort at gmail.com
Thu Dec 1 02:58:25 EST 2011
Havard,
"labelpnt generates a point with its center at the middle of the
bounding rectangle of the text."
Unless there's a problem with the code, this is not the behavior of
the labelpnt geomtransform. The point created by labelpnt is dependant
on the label's POSITION, i.e. it is the center of the text's bounding
rectangle only if the label is in position CC.
regards,
thomas
On Thu, Dec 1, 2011 at 08:47, Havard Tveite <havard.tveite at umb.no> wrote:
> The documentation has been updated.   An example of GEOMTRANSFORM
> usage has been added in the label document under STYLE.
> http://gis.umb.no/~havatv/mapserver/docs/mapfile/label.html#label-style
> Håvard
> On 11/30/2011 5:09 AM, Stephen Woodbridge wrote:
>> On 11/29/2011 10:19 PM, Matt Pettis wrote:
>>> I see upon reading closer that it is deprecated... but I thought that
>>> meant
>>> it was discouraged, but not yet removed.  That must not be true... I am
>>> now
>>> working to find a GEOMTRANSFORM example to help me do the equivalent.
>> Hi Matt,
>> These should help you:
>> http://mapserver.org/mapfile/style.html
>> http://mapserver.org/development/rfc/ms-rfc-72.html
>> http://mapserver.org/trunk/MIGRATION_GUIDE.html
>> Also please write a Bug and assign it to the Documentation and the fact
>> that it has been removed. It might be nice to add a comment in the docs
>> that points to the MIGRATION_GUIDE.
>> Thanks,
>>    -Steve W
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Håvard Tveite
> Department of Mathematical Sciences and Technology, UMB
> Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
> Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
