[mapserver-users] Reloading MapCache configuration file on changes?
John Taranu
jtaranu at firstbasesolutions.com
Mon Dec 5 17:37:02 EST 2011
Thomas,
Is there a better way force MapCache to reload its configuration script than
restarting apache? I'm working on an application that will use two
load-balanced web servers running MapCache, all pointing to a single central
tile repository and a single central .xml configuration file. The
configuration file will occasionally be edited, either with deletions or
additional tilesets. Both web servers need to reload the updated
configuration .xml.
Is it possible to set up MapCache to check if the config file was recently
updated and, if so, reload the config .xml? It looks like this is currently
enabled under FastCGI, but not under Apache.
John
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111205/d826c2b6/attachment.html
