[mapserver-users] Re: Reloading MapCache configuration file on
changes?
thomas bonfort
tbonfort at terriscope.fr
Tue Dec 6 06:00:59 EST 2011
AFAIK, this isn't possible. Inside an apache module, the configuration
is considered read-only as it is shared between multiple worker
threads/processed spawned by httpd.
apachectl configtest && apachectl graceful will restart the server
gracefully, i.e. without aborting ongoing requests, and will load the
new configuration for subsequent requests.
thomas
On Mon, Dec 5, 2011 at 23:37, John Taranu
<jtaranu at firstbasesolutions.com> wrote:
> Thomas,
> Is there a better way force MapCache to reload its configuration script than
> restarting apache? I’m working on an application that will use two
> load-balanced web servers running MapCache, all pointing to a single central
> tile repository and a single central .xml configuration file. The
> configuration file will occasionally be edited, either with deletions or
> additional tilesets. Both web servers need to reload the updated
> configuration .xml.
> Is it possible to set up MapCache to check if the config file was recently
> updated and, if so, reload the config .xml? It looks like this is currently
> enabled under FastCGI, but not under Apache.
> John
