[mapserver-users] GEOMTRANSFORM LABELPNT example
Ian Walberg ian.walberg at airborne.aero
Sun Dec 11 10:20:28 EST 2011
Here is the map file we are using ms4w  3.0.3.
We thought the larger grey circle should be drawn in the center of the
label text.
What have we done wrong?
Thanks
Ian
LAYER
               DEBUG 5
               NAME Test
               TYPE annotation
               STATUS DEFAULT
               FEATURE
    POINTS
      -122 33
    END
    TEXT "Some label text"
               END
               CLASS
                              LABEL
                                             FONT "arialuni"
                                             TYPE truetype
                                             ENCODING 'UTF-8'
                                             SIZE 14
                                             COLOR 255 255 0
                                             POSITION LR
                                             OFFSET 8 8
                                             STYLE
                                               GEOMTRANSFORM LABELPOLY
                                               COLOR 200 50 50
                                             END
                                             STYLE
        SYMBOL 'circle'
                                               COLOR 100 100 100
                                                            SIZE 20
                                             END
                                             STYLE
                                               COLOR 255 255 255
                                               SYMBOL 'circle'
                                               SIZE 6
                                             END
                              END
  END
END
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Ian
Walberg
Sent: Saturday, December 10, 2011 3:53 PM
To: Brent Fraser
Cc: mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] GEOMTRANSFORM LABELPNT example
Brent,
We copied the example
http://osgeo-org.1803224.n2.nabble.com/GEOMTRANSFORM-labelpnt-location-t
<http://osgeo-org.1803224.n2.nabble.com/GEOMTRANSFORM-labelpnt-location-
t>
d6408065.html.
However we see the GEOMTRANSFORM labelpnt drawing the circle on the
point location not the center of the label text.
Thanks
Ian
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
<mailto:[mailto:bfraser at geoanalytic.com]>
Sent: Saturday, December 10, 2011 1:25 PM
To: Ian Walberg
<mailto:mapserver-users at lists.osgeo.org>
Ian,
  How are you specifying it in your mapfile?
Brent Fraser
> Steve,
> We are still not seeing what we expect, we are testing with the ms4w
> 3.0.3 install, will this work?
> Thanks
> Ian
> From: mapserver-users-bounces at lists.osgeo.org
<mailto:mapserver-users-bounces at lists.osgeo.org>
<mailto:[mailto:mapserver-users-bounces at lists.osgeo.org]>  On Behalf Of
Stephen
> Woodbridge
> Sent: Saturday, December 10, 2011 7:48 AM
> To: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] GEOMTRANSFORM LABELPNT example
> On 12/10/2011 10:36 AM, Ian Walberg wrote:
>> Does anyone have an example of the GEOMTRANSFORM LABELPNT?
>> We have been trying this I were expecting the center to be located on
>> the center of the label test border rectangle but  we seem to be
>> getting the center as the point location.
>> Any ideas?
> Hi Ian,
> The label point is the that the label is placed about. The actual
> label position can change relative to the label point based on
> POSITION and other attributes of the label.
> I don't have the RFC in front of me but here is a good example to test
> with:
<http://osgeo-org.1803224.n2.nabble.com/GEOMTRANSFORM-labelpnt-location>
> -t
> d6408065.html
> Try varying the LABEL POSITION and see how it behaves.
> -Steve W
<http://lists.osgeo.org/mailman/listinfo/mapserver-users>
mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111211/98d3e544/attachment.html
