[mapserver-users] GEOMTRANSFORM LABELPNT example
thomas bonfort
thomas.bonfort at gmail.com
Sun Dec 11 14:26:27 EST 2011
I think this is all expected behavior, although the documentation may
be incorrect.
LABELPNT draws a marker on the geographic position the label is
attached to. This corresponds to the center of the label text only if
the label is in position CC.
To draw a label at the center of the label text, another geomtransform
would have to be implemented, named e.g. LABELBBOXCENTROID.
regards,
thomas
On Sun, Dec 11, 2011 at 19:34, Brent Fraser <bfraser at geoanalytic.com> wrote:
> Hey Jeff,
> I've been looking into this too (not finished yet). I'm using v6.0.1 and
> can reproduce my original results (blue dot to the left) AND Ian's (grey dot
> coincident with white dot). Very strange. My shapefile dataset gets
> reprojected from geographic to UTM, so that may be causing the difference.
> I need to look into that...
> Best Regards,
> Brent Fraser
> On 12/11/2011 10:57 AM, Jeff McKenna wrote:
>> On 11-12-11 11:20 AM, Ian Walberg wrote:
>>> Here is the map file we are using ms4w 3.0.3.
>>> We thought the larger grey circle should be drawn in the center of the
>>> label text.
>>> What have we done wrong?
>> I have done some testing on this on Windows, with MapServer trunk
>> (6.1-dev), here are my findings:
>> - I used Brent's original example styles (from
>> http://osgeo-org.1803224.n2.nabble.com/GEOMTRANSFORM-labelpnt-location-td6408065.html)
>> with Ian's FEATURE layer --> Brent's "Blue Dot" LABELPNT with POSITION CC is
>> now correctly placed in the center of the label text (so it seems this has
>> been fixed in the code, but I can't find the ticket that says that)
>> - If I change to POSITION LR (as in Ian's example layer) then I get Ian's
>> issue (LABELPNT is placed at the geometry location, not in the center of the
>> label text
>> - but this is now an issue of understanding the developer's logic (from
>> that thread SteveL says "Let me ponder this and get back to you. I think it
>> makes sense to use the label point geotransform only with position CC so
>> that it matches actual shape location.")
>> That's all I know at this point (ha pun).
>> -jeff
> mapserver-users at lists.osgeo.org
