[mapserver-users] mapserver compiled with jpeg v7 and GDAL with internal JPEG results in core dumps (SIGSEGV)
Ethan Alpert ealpert at digitalglobe.com
Wed Dec 14 18:41:25 EST 2011
I've been running down a mapserver core dump for most of the day. It
appears that when I compile GDAL 1.8.1 with it's internal JPEG library
and mapserver links to libjpeg.so.7 BAD things happen.
I tried compiling mapserver with -without-jpeg but configure errors out:
configure: checking whether we should include JPEG support...
configure: error: "Could not find jpeglib.h or
libjpeg.a/libjpeg.so/libjpeg.dylib in
/dg/local/apps/osgeo_pack/source/build/mapserver-6.0.1/no."
It appears that when linking mapserver GDAL's internal version of
jpeg_CreateDecompress is not used during a GDALOpenShared. Instead the
libjpeg linked to mapserver is used which in this case is jpeg 7.
GDAL dies horribly.
Not sure what to do about this. Going to think about it overnight.
-e
This electronic communication and any attachments may contain confidential and proprietary
information of DigitalGlobe, Inc. If you are not the intended recipient, or an agent or employee
responsible for delivering this communication to the intended recipient, or if you have received
this communication in error, please do not print, copy, retransmit, disseminate or
otherwise use the information. Please indicate to the sender that you have received this
communication in error, and delete the copy you received. DigitalGlobe reserves the
right to monitor any electronic communication sent or received by its employees, agents
or representatives.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20111214/5cea4aa7/attachment.html
