[mapserver-users] mapserver compiled with jpeg v7 and GDAL with internal JPEG results in core dumps (SIGSEGV)
Ethan Alpert ealpert at digitalglobe.com
Thu Dec 15 17:21:22 EST 2011
It builds find but gdal_translate complains when you run it that the jpeg version is not 62
-----Original Message-----
From: Even Rouault [mailto:even.rouault at mines-paris.org]
Sent: Thursday, December 15, 2011 11:29 AM
To: Ethan Alpert
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] mapserver compiled with jpeg v7 and GDAL with internal JPEG results in core dumps (SIGSEGV)
Le jeudi 15 décembre 2011 17:23:28, Ethan Alpert a écrit :
> I agree. Problem here is I now have to downgrade jpeg because GDAL will
> only work with v62.
Are you sure of that ? Did you try to build against libjpeg v7 ? Did you get
error messages ?
This electronic communication and any attachments may contain confidential and proprietary
information of DigitalGlobe, Inc. If you are not the intended recipient, or an agent or employee
responsible for delivering this communication to the intended recipient, or if you have received
this communication in error, please do not print, copy, retransmit, disseminate or
otherwise use the information. Please indicate to the sender that you have received this
communication in error, and delete the copy you received. DigitalGlobe reserves the
right to monitor any electronic communication sent or received by its employees, agents
or representatives.
