[mapserver-users] Re: Queryfile w/ ms 5.6.3
Richard Greenwood
richard.greenwood at gmail.com
Fri Dec 16 09:43:20 EST 2011
On Fri, Dec 16, 2011 at 5:44 AM, <nikos at maich.gr> wrote:
> Hi,
> Trying to clarify as best as I can..
> Simply adding a queryfile parameter (queryfile does exist) ms seg faults on
> Linux and hangs on win
> 1. This does NOT choke on XP ms 5.3-dev, dont have an old ms for linux
> (mandriva)to test..
> This chokes, seg faults on Linux, and hangs on windows,
> /var/www/html/cgi-bin/fw/mapserv -nh
> "QUERY_STRING=queryfile=/var/www/html/IUNG/tmp/IUNG1324032812.qy&img.x=135&img.y=242&savequery=true&zoomdir=1&zoomsize=2&map=/var/www/html/IUNG/IUNG_aoa.map&imgext=361228.892188
> 4364612.298438 369032.295312
> 4372415.701562&mapext=shape&layer=municipalities"
> nothing is reported in ms_error, debug 5
Nikos -
Did you create your query files with the same version of MapServer as
you are truing to read it with?
Rich
Richard Greenwood
www.greenwoodmap.com
