[mapserver-users] Re: Re: Queryfile w/ ms 5.6.3 (Richard Greenwood)
nikos at maich.gr nikos at maich.gr
Mon Dec 19 03:26:56 EST 2011
 Hi Richard,
 Yes, the queryfiles are created/read with their respective versions,
 and actually, for kicks, I tried using a 5.3 queryfile on 5.7 and MS
 correctly complained "Hmm, this does not look a queryfile..."
 regards,
 nikos
> On Fri, Dec 16, 2011 at 5:44 AM,  <nikos at maich.gr> wrote:
>> Hi,
>> Trying to clarify as best as I can..
>> Simply adding a queryfile parameter (queryfile does exist) ms seg
>> faults on
>> Linux and hangs on win
>> 1. This does NOT choke on XP ms 5.3-dev, dont have an old ms for
>> linux
>> (mandriva)to test..
>> This chokes, seg faults on Linux, and hangs on windows,
>> /var/www/html/cgi-bin/fw/mapserv -nh
>> "QUERY_STRING=queryfile=/var/www/html/IUNG/tmp/IUNG1324032812.qy&img.x=135&img.y=242&savequery=true&zoomdir=1&zoomsize=2&map=/var/www/html/IUNG/IUNG_aoa.map&imgext=361228.892188
>> 4364612.298438 369032.295312
>> 4372415.701562&mapext=shape&layer=municipalities"
>> nothing is reported in ms_error, debug 5
> Nikos -
> Did you create your query files with the same version of MapServer as
> you are truing to read it with?
> Rich
> Richard Greenwood
> richard.greenwood at gmail.com
> www.greenwoodmap.com
