[mapserver-users] Substitution variable
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Dec 19 14:15:23 EST 2011
On 11-12-19 3:08 PM, scott159 at free.fr wrote:
> Hi,
> I try to implement substitution variable with mapserver 6. I add in URL "&attribute=value" and the mapfile contains :
> DATA "D:\tmp\%attribute%\data.shp"
> But when I launch the URL "http://.....mapserv.exe?map=....&attribute=value", I have a error because mapserver can't load data from D:\tmp\%attribute%\data.shp. Why the substitution doesn't work ? Is there a configuration to add in Apache, in mapfile to success ?
Scott,
I recently created a small test package for variable substitution, that
contains a small working mapfile:
http://labs.gatewaygeomatics.com/dl/ogr-outputformat.zip You could check
that mapfile to see the syntax. Also, a full discussion is in the
related ticket: http://trac.osgeo.org/mapserver/ticket/3751
I wish everyone a merry Christmas.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
