[mapserver-users] Substitution variable
Lime, Steve D (DNR) Steve.Lime at state.mn.us
Mon Dec 19 14:59:53 EST 2011
Pay particular attention to the validation block... You *must* set that up or no substitution will be done.
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Jeff McKenna
Sent: Monday, December 19, 2011 1:15 PM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Substitution variable
On 11-12-19 3:08 PM, scott159 at free.fr wrote:
> Hi,
> I try to implement substitution variable with mapserver 6. I add in URL "&attribute=value" and the mapfile contains :
> DATA "D:\tmp\%attribute%\data.shp"
> But when I launch the URL "http://.....mapserv.exe?map=....&attribute=value", I have a error because mapserver can't load data from D:\tmp\%attribute%\data.shp. Why the substitution doesn't work ? Is there a configuration to add in Apache, in mapfile to success ?
Scott,
I recently created a small test package for variable substitution, that
contains a small working mapfile:
http://labs.gatewaygeomatics.com/dl/ogr-outputformat.zip You could check
that mapfile to see the syntax.  Also, a full discussion is in the
related ticket: http://trac.osgeo.org/mapserver/ticket/3751
I wish everyone a merry Christmas.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
