[mapserver-users] Fwd: WFS Filters Encoding
Jeff Konnen
jaykayone at gmail.com
Mon Dec 19 15:33:17 EST 2011
> Hi
> We are using Mapserver 6.0.1 on linux with a postgis database.
> We have some wfs services that used to work correctly in earlier versions of mapserver.
> In version 6, we observed the following: when people use a wfs filter on a string field with a numeric value <PropertyIsEqualTo><PropertyName>code_commu</PropertyName><Literal>105</Literal></PropertyIsEqualTo>, mapserver will generate a sql statement without quotes assuming that the Literal is an Integer.
> To fix this i have to use the "gml_types" "auto" directive.
> now the filter works but it alters the describefeature xml document by setting the attribute types to 'Character'. This however does not seem to be valid xml, at least my client (FME) does not to seem to like this type declarations, telling me that they are not valid...
> Is there another way to fix the filter issue?
> There is a similar problem with the PropertyIsLike operator but I could not make it work at allin version 6.0.1
> Thanks in advance for your help
> Best regards
> Jeff
