[mapserver-users] Re: Some PointSymbolizer values are being ignored. SLD Syntax problem?
thomas bonfort thomas.bonfort at gmail.com
Tue Dec 20 08:01:41 EST 2011
Joanne,
I have committed a potential fix in
http://trac.osgeo.org/mapserver/changeset/12904 , but I am not setup
to test SLD. Please open a ticket for the issue and report your
findings there.
regards,
thomas
On Mon, Dec 19, 2011 at 23:30, myOpenLayersUName
<joanne.mcgraw at sympatico.ca> wrote:
> Hello everyone,
> I've come back to this problem I submitted to the forum last month re: my
> PointSymbolizer's fill-opacity, stroke-opacity and stroke-width being
> ignored. I'm no further ahead, so I thought I'd update what I've read and
> tried, just to see if that jogs anyone's thoughts in terms of some issue
> related to this that I'm not aware of.
> I am fairly certain this functionality is supported, given what I read in
> the "SLD implementation - fill-opacity" post thread
> (http://osgeo-org.1803224.n2.nabble.com/SLD-implementation-fill-opacity-td1971368.html)
> from 2008.
> I've worked through the StyledLayerDescriptor.xsd as best I can and believe
> my definition is correct syntactically. I also tried creating a Polygon
> layer and applying a similarly-defined PolygonSymbolizer SLD to the one I am
> using for the PointSymbolizer to see if my syntax was correct (as much as I
> could given the two different types of data). This, too, suggests it is
> fine. When using the PolygonSymbolizer definition below, the fill-opacity
> and stroke-width values are applied in the output. Granted, the the
> stroke-opacity is still not but at least something worked that doesn't with
> the PointSymbolizer.
> I'm including an attachment that shows the results of using the two SLDs
> included in this thread (my PointSymbolizer and the PolygonSymbolizer
> above). The definitions are as close to the same as I can make them but, as
> you can see, the output is not. In the Point symbology, the fill-opacity
> (0.4), stroke-opacity (0.6) and stroke-width (10.0) are being ignored; and,
> in the Polygon symbology, the stroke-opacity (0.6) is being ignored but the
> fill-opacity (0.4) and stoke-width (10.0) are being correctly applied.
> http://osgeo-org.1803224.n2.nabble.com/file/n7110031/Point_vs._Polygon.png
> Could there be an issue with my Mapfile definition? In case it matters, here
> is my OUTPUTFORMAT definition for the Point and Polygon layers used above
> and the Point layer definition:
> I really can't imagine what else to try...Is it possible this stuff is
> broken in 6.0.1?
> Cheers,
> jtm
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Some-PointSymbolizer-values-are-being-ignored-SLD-Syntax-problem-tp7028772p7110031.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
