[mapserver-users] - SQL Server 2008
scott159 at free.fr scott159 at free.fr
Mon Dec 26 07:46:15 EST 2011
I would like connect MapServer 6.0.1 to MS SQL Server 2008. To use OGR driver with FreeTDS I try :
- to install FreeTDS from .\freetds-0.91 :
./configure --with-tdsver=7.2
sudo make
make install
make clean
Configure with only --with-tdsver ?
- to edit freetds.conf to configure MS Sql Server 2008 :
[servername1]
host = XX.XX.XX.XX
port = 1433
Only 2 variables to configure ?
- to try to connect MS SQL Server 2008 with ogrinfo :
ogrinfo -al "MSSQL:server=servername1;driver=FreeTDS;database=EXAMPLE;trusted_connection=yes"
How ogrinfo can find freetds.conf file ?
servername1 must be found in freetds.conf ?
gdal 1.8 is it necessary to specify driver=FreeTDS ?
But it's doesn't work, so I can't try with mapfile ;-(
What's wrong ?
scott
