[mapserver-users] Order of attributes returned from WFS GetFeature
Dejan Gambin
dejan.gambin at coin.hr
Thu Dec 29 06:19:44 EST 2011
Thanks,
I tried something like:
DATA "the_geom from (select the_geom, attr1, attr2 from table) as new_table using unique gid"
but this doesn't work. Can you tell me how should such a query look like? Now it is like:
DATA "the_geom from table using unique gid"
Thanks very much
regards, dejan
On 27. pro. 2011., at 22:13, Rahkonen Jukka wrote:
> Hi,
> The WFS standard defines that attributes are included in a XML sequence. Therefore the returned attributes must be in the same order than in the schema of your feature type.
> I would suggest also having a try with editing the SQL in the DATA line and selecting attributes as you like but check first if it has an effect on the schema returned by DescribeFeatureType.
> -Jukka Rahkonen-
> ________________________________________
> Lime, Steve D (DNR) wrote:
>> I don't believe you can control this on the MapServer side. Why not just set the column order
>> explicitly in the SQL statement?
>> Steve
>> -----Original Message-----
>> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf > Of Dejan Gambin
>> Sent: Thursday, December 22, 2011 7:40 AM
>> To: mapserver-users at lists.osgeo.org
>> Subject: [mapserver-users] Order of attributes returned from WFS GetFeature
>> Hi,
>> I am using GetFeature request to get the attributes from my PostGIS data. I define attributes with "gml_include_items". The order of attributes is however related to postgis column order, not to the order in gml_include_items.
> Is it somehow possible to change the order, withoout need to modify column order in PostGIS/PostgreSQL?
> regards, dejan_______________________________________________
