[mapserver-users] mapscript php with agg rendering?
Pavel Iacovlev
iacovlev.pavel at gmail.com
Tue Feb 15 09:16:00 EST 2011
Can you post your .php file ?
On Tue, Feb 15, 2011 at 3:56 PM, Michael Schulz
<mandschulz at googlemail.com>wrote:
> Hi,
> yeah, unfortunately I tried that one already, but it didn't work
> either. Although "IMAGETYPE aggpng24" now shows up in the saved
> mapfile, but the rendered output is still definitely GD and not AGG.
> I found this in trac http://trac.osgeo.org/mapserver/ticket/2813, it's
> a bit old but that seems exactly my problem, only the solution doesn't
> workforme.
> Thx, Michael
> 2011/2/15 Pavel Iacovlev <iacovlev.pavel at gmail.com>:
> > Use the predefined one:
> > $map->selectOutputFormat('AGGPNG24');
> > On Tue, Feb 15, 2011 at 1:37 PM, Michael Schulz <
> > wrote:
> >> Hi mapservers,
> >> I have a question regarding the AGG rendering when creating a map
> >> completly from php-mapscript. In the script I (think I) am setting all
> >> the required parameters for the map to be rendered with AGG using
> >> 24bit:
> >> $oMap=ms_newMapObjFromString("MAP END");
> >> $oMap->outputformat->set('name','png');
> >> $oMap->outputformat->set('driver','AGG/PNG');
> >> $oMap->outputformat->set('mimetype','image/png');
> >> $oMap->outputformat->set('imagemode',MS_IMAGEMODE_RGBA);
> >> $oMap->outputformat->set('extension','png');
> >> $oMap->outputformat->set('transparent',MS_TRUE);
> >> I've experienced for some time with the following directive, trying to
> >> actually invoke the correct outputformat
> >> $oMap->selectoutputformat("png");
> >> But to no avail. The maps that derive from this script clearly use the
> >> GD driver. When I saved the generated map-file to the filesystem I
> >> found the following line in the map section:
> >> IMAGETYPE gif
> >> I am using MapServer, Mapscript 5.6.6., PHP 5.3.3 on OpenSuse 11.3
> >> Maybe someone could share some mapscript code or has some hints how to
> >> actually return AGG rendered maps.
> >> Thanks, Michael
> >> Michael Schulz
> >> _______________________________________________
> >> mapserver-users mailing list
> >> mapserver-users at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Michael Schulz
> Christoph-Mang-Str. 5
> D-79100 Freiburg
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110215/dfee7486/attachment.html
