[mapserver-users] mapscript php with agg rendering?
Michael Schulz
mandschulz at googlemail.com
Tue Feb 15 09:52:14 EST 2011
I am working on a stripped-down version, to rule out other
interferences and then to post it...
Cheers, Michael
2011/2/15 Pavel Iacovlev <iacovlev.pavel at gmail.com>:
> Can you post your .php file ?
> On Tue, Feb 15, 2011 at 3:56 PM, Michael Schulz <mandschulz at googlemail.com>
> wrote:
>> Hi,
>> yeah, unfortunately I tried that one already, but it didn't work
>> either. Although "IMAGETYPE aggpng24" now shows up in the saved
>> mapfile, but the rendered output is still definitely GD and not AGG.
>> I found this in trac http://trac.osgeo.org/mapserver/ticket/2813, it's
>> a bit old but that seems exactly my problem, only the solution doesn't
>> workforme.
>> Thx, Michael
>> > Use the predefined one:
>> > $map->selectOutputFormat('AGGPNG24');
>> > On Tue, Feb 15, 2011 at 1:37 PM, Michael Schulz
>> > wrote:
>> >> Hi mapservers,
>> >> I have a question regarding the AGG rendering when creating a map
>> >> completly from php-mapscript. In the script I (think I) am setting all
>> >> the required parameters for the map to be rendered with AGG using
>> >> 24bit:
>> >> $oMap=ms_newMapObjFromString("MAP END");
>> >> $oMap->outputformat->set('name','png');
>> >> $oMap->outputformat->set('driver','AGG/PNG');
>> >> $oMap->outputformat->set('mimetype','image/png');
>> >> $oMap->outputformat->set('imagemode',MS_IMAGEMODE_RGBA);
>> >> $oMap->outputformat->set('extension','png');
>> >> $oMap->outputformat->set('transparent',MS_TRUE);
>> >> I've experienced for some time with the following directive, trying to
>> >> actually invoke the correct outputformat
>> >> $oMap->selectoutputformat("png");
>> >> But to no avail. The maps that derive from this script clearly use the
>> >> GD driver. When I saved the generated map-file to the filesystem I
>> >> found the following line in the map section:
>> >> IMAGETYPE gif
>> >> I am using MapServer, Mapscript 5.6.6., PHP 5.3.3 on OpenSuse 11.3
>> >> Maybe someone could share some mapscript code or has some hints how to
>> >> actually return AGG rendered maps.
>> >> Thanks, Michael
>> >> Michael Schulz
>> >> _______________________________________________
>> >> mapserver-users mailing list
>> >> mapserver-users at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Michael Schulz
>> Christoph-Mang-Str. 5
>> D-79100 Freiburg
Michael Schulz
D-79100 Freiburg
