[mapserver-users] Help with runtime variable substitution in
inline ODBC virtual data sources
Brent Fraser
bfraser at geoanalytic.com
Tue Feb 15 18:55:33 EST 2011
Brent,
I did something similar a while ago. I connected to an aspatial SQL
Server instance using an OGR VRT definition pointing to an ODBC datasource:
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION "<OGRVRTDataSource>
<OGRVRTLayer name='mypoints'>
<SrcDataSource>ODBC:myuser/mypass at MyODBC,view_of_points</SrcDataSource>
<SrcSQL>
SELECT * FROM view_of_points
WHERE StatusID=%StatusID%
</SrcSQL>
<FID>PointID</FID>
<GeometryType>wkbPoint</GeometryType>
<GeometryField encoding='PointFromColumns' y='MyLatitude' x='MyLongitude'/>
<LayerSRS>NAD83</LayerSRS>
</OGRVRTLayer>
</OGRVRTDataSource>"
PROCESSING "CLOSE_CONNECTION=DEFER"
DATA "view_of_points"
PROJECTION
'proj=longlat'
'ellps=GRS80'
'datum=NAD83'
'no_defs'
END
Note that StatusId was passed as a CGI variable.
Best Regards,
Brent Fraser
On 2/15/2011 4:36 PM, pcreso at pcreso.com wrote:
> Hi,
> I'm looking to set up a mapfile with an inline ovf data source as
> described in part 2 of section 5 at
> http://mapserver.org/input/vector/VirtualSpatialData.html
> I'm also looking to embed an SQL in the ovf with a where clause, using
> runtime variable substitution as described at
> http://mapserver.org/cgi/runsub.html?highlight=variable
> The latter says that such runtime substitution is supported in the
> CONNECTION & DATA fields within the LAYER object.
> I'm unclear as to how a where clause can be inserted in the ovf
> definition, and am hoping that this will be in the CONNECTION or DATA
> fields, and is amenable to runtime variable substitution.
> Basically with the URL including: &job_id=23
> have an ovf where clause specified like: ...
> where job=%job_id%
> thus from this
> have an ovf ODBC connection pass a where clause like: and job_id=23
> This is connecting to an aspatial Oracle database returning up to 100
> point features from a table with X Y columns..
> Can anyone provide some hints on:
> 1. Is this possible?
> 2. How best to implement it?
> Thanks,
> Brent Wood
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110215/c53b7e6c/attachment.html
