[mapserver-users] Help with runtime variable substitution in
inline ODBC virtual data sources
Jean-François Gigand
jean-francois at gigand.fr
Tue Feb 15 18:59:14 EST 2011
Hi Brent,
I never worked with virtual data source but have some experience of OGR.
The original documentation of the format of OGR virtual data source is here:
http://www.gdal.org/ogr/drv_vrt.html
To my understanding, the way to specify a WHERE condition is by
writing the full ODBC query using the <SrcSQL> element in
<OGRVRTLayer> (instead of <SrcLayer>).
This way (OGR-level), the SQL is forwarded by OGR to the ODBC driver,
so quite low-level.
2011/2/16 <pcreso at pcreso.com>
> Hi,
> I'm looking to set up a mapfile with an inline ovf data source as described in part 2 of section 5 at http://mapserver.org/input/vector/VirtualSpatialData.html
> I'm also looking to embed an SQL in the ovf with a where clause, using runtime variable substitution as described at http://mapserver.org/cgi/runsub.html?highlight=variable
> The latter says that such runtime substitution is supported in the CONNECTION & DATA fields within the LAYER object.
> I'm unclear as to how a where clause can be inserted in the ovf definition, and am hoping that this will be in the CONNECTION or DATA fields, and is amenable to runtime variable substitution.
> Basically with the URL including: &job_id=23
> have an ovf where clause specified like: ... where job=%job_id%
> thus from this
> have an ovf ODBC connection pass a where clause like: and job_id=23 ..."
> This is connecting to an aspatial Oracle database returning up to 100 point features from a table with X Y columns..
> Can anyone provide some hints on:
> 1. Is this possible?
> 2. How best to implement it?
> Thanks,
> Brent Wood
> mapserver-users at lists.osgeo.org
