[mapserver-users] Expression and nquery with sde issue
Mario Franco
mario.franco at ydreams.com
Fri Jul 15 06:14:08 EDT 2011
I having two issues with mapserver if anyone can help me I would be
appreciated.
The first has to do with an Expression in a class:
I have a shape with an attribute with the 172060.0937 but when add to
the class:
> EXPRESSION ( [AREA] = 172060.0937 )
The problem is that this expression returns false because mapserver is
rounding the double value from the database. If I compare with:
> EXPRESSION ( [AREA] = 172060)
it works. There is any way to turn this off or to increase the precision?
The second issue is:
I'm using this url
(http://localhost:82/cgi-bin/mapserv.exe?map=D%3a\projects\Inag\InterSIG+II\InterSIG+Website\Trunk\InterSIG+ASP.NET\Maps%2fintersig_281.map&qlayer=Concelhos&layers=Concelhos&MAPSIZE=629%20467&MINX=-232614.525612302&MINY=-49761.6088409424&MAXX=676601.080299802&MAXY=625284&mode=NQUERY&MAPSHAPE=POLYGON%28%28-232614%20-49761,%20-232614%20625284,%20676601%20625284,%20676601%20-49761,%20-232614%20-49761%29%29)
to execute a nquery but I always get the error "msSDELayerGetShape():
SDE error. SE_stream_fetch_row(): Invalid parameter value passed to
function. (-66) "
The log doesn't help that much:
> [Fri Jul 15 10:47:19 2011].20000 msSDELayerOpen(): Layer Concelhos
> opened from scratch.
> [Fri Jul 15 10:47:23 2011].35000
> msConnPoolRegister(Concelhos,ydinag2,port:5151,sde,sde,sde,01D6BCC0)
> [Fri Jul 15 10:47:23 2011].35000 msSDELayerOpen(): Layer Concelhos
> specified version SDE.DEFAULT.
> [Fri Jul 15 10:47:23 2011].42000 msSDEGetLayerInfo(): Looking for
> layer by SDE.CONCELH_PTCONT_2008_0_596, SHAPE,
> [Fri Jul 15 10:47:23 2011].42000 msSDEGetLayerInfo(): No cached
> layerid found.
> [Fri Jul 15 10:47:23 2011].63000 msSDELCacheAdd(): Caching id for
> SDE.CONCELH_PTCONT_2008_0_596, SHAPE, ydinag2,port:5151,sde,sde,sde
> [Fri Jul 15 10:47:23 2011].72000 Getting all column information in
> msSDELayerInitItemInfo
> [Fri Jul 15 10:47:23 2011].79000 msSDELayerInitItemInfo(): getting
> info for DICO
> info for CONCELHO
> info for DI
> info for DISTRITO
> info for CCDR
> info for NUT3
> info for NUT3_NOME
> info for NUT2
> info for NUT2_NOME
> info for AREA2008_1
> info for objectid
> info for SHAPE
> [Fri Jul 15 10:47:23 2011].79000 Column information has already been
> gotten... returning from msSDELayerInitItemInfo
> [Fri Jul 15 10:47:43 2011].122000 msSDELayerGetShape(): SDE error.
> SE_stream_fetch_row(): Invalid parameter value passed to function. (-66)
> [Fri Jul 15 10:47:43 2011].126000 msFreeMap(): freeing map at 01D3EFE8.
> [Fri Jul 15 10:47:43 2011].126000 msSDELayerCloseConnection(): Closing
> connection for layer Concelhos.
> msConnPoolRelease(Concelhos,ydinag2,port:5151,sde,sde,sde,01D6BCC0)
> msConnPoolClose(ydinag2,port:5151,sde,sde,sde,01D6BCC0)
> [Fri Jul 15 10:47:43 2011].156000 msSDELayerClose(): Closing layer
> Concelhos.
> msConnPoolRelease(Concelhos,ydinag2,port:5151,sde,sde,sde,00000000)
> [Fri Jul 15 10:47:43 2011].156000 msConnPoolRelease(): Unable to find
> handle for layer 'Concelhos'.
> [Fri Jul 15 10:47:43 2011].156000 msConnPoolRelease(): General error
> message. Unable to find handle for layer 'Concelhos'.
Here part of my configuration:
> LAYER
> NAME "Concelhos"
> METADATA
> "wms_title" "Concelhos" # required
> "wfs_title" "Concelhos" # required
> "gml_featureid" "ID" ## REQUIRED
> "gml_geometries" "geom"
> "gml_geom_type" "polygon"
> "gml_include_items" "all" # Optional (serves all attributes for layer)
> "gml_exclude_items" "GEOMETRY,OBJECTID"
> "ows_include_items" "all"
> "ows_exclude_items" "GEOMETRY,OBJECTID"
> END
> DUMP true
> TOLERANCE 10
> TOLERANCEUNITS meters
> TYPE polygon
> #CONNECTIONTYPE SDE
> CONNECTIONTYPE PLUGIN
> PLUGIN "D:/ms4w/Apache/specialplugins/msplugin_sde_92.dll"
> CONNECTION "ydinag2,port:5151,sde,sde,sde"
> DATA "SDE.CONCELH_PTCONT_2008_0_596,SHAPE,SDE.DEFAULT"
> PROJECTION
> "init=EPSG:3763" #--sistema de coordenadas desta layer na origem
> END
> STATUS ON
> OPACITY 100
> TEMPLATE '../Templates/Identify/t.html'
I'm using Mapserver 5.6.3, I know it's not the latest but I didn't
updated yet.
Any help would be useful and thx in advance.
Mário Franco
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110715/8c79f7e7/attachment.html
