[mapserver-users] ms4w 2.3.1. and ArcSDE
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Jul 19 10:45:52 EDT 2011
Thanks Brent. Indeed to access SDE layers with MS4W 3.0.x please follow
your local README (or online at:
http://www.maptools.org/ms4w/index.phtml?page=README_INSTALL.html#sde).
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 11-07-19 11:26 AM, Brent Fraser wrote:
> Flavio,
> Last year I experimented with MS4W and SDE 9.3
> (http://lists.maptools.org/pipermail/ms4w-users/2010-January/001402.html).
> I used a couple of Windows tools: Dependency Walker (to see which DLLs a
> DLL depends on), and Process Monitor (to see which files, including
> DLLs, a process is trying to load at run time).
> Best Regards,
> Brent Fraser
> On 7/19/2011 2:46 AM, Flavio Hendry wrote:
>> Hi all
>> Anyone successful installing and connecting to ArcSDE (9.0, SQL
>> Server) with ms4w 2.3.1? We followed all instructions, however we get
>> an internal server error ([error] [client 127.0.0.1] Premature end of
>> script headers: php-cgi.exe) when trying to connect (see MapFile
>> extract below). One problem could be that in 2.3.1 ms4w was compiled
>> using GDAL 1.6 and the GDAL/OGR SDE DLLs with GDAL 1.5 ... However, I
>> do not see any dependency problems ...
>> - ArcSDE SDK is installed, added to path
>> - GDAL/OGR plug-ins are copied to "gdalplugins" dir and load the
>> sde90.dll (dependencies), however work with GDAL 1.5
>> - msplugin_sde_90.dll loads sde90.dll etc. (dependencies), works with
>> GDAL 1.6
>> - ogrinfo --formats does not show SDE
>> Any hints or ideas? THX!
>> LAYER
>> NAME "Basemap"
>> TYPE POINT
>> CONNECTIONTYPE PLUGIN
>> CONNECTION "xxx.xxx.xx.x,port:5151,sde,uid,password"
>> PLUGIN "C:/ms4w/Apache/specialplugins/msplugin_sde_90.dll"
>> DATA "SDE.Test,SHAPE,SDE.DEFAULT"
>> CLASS
>> STYLE
>> SYMBOL 'continue'
>> SIZE 1
>> COLOR -255 0 0
>> END
>> END
>> PROJECTION
>> "init=epsg:23033"
>> END
>> END
>> Mit freundlichem Gruss / Best regards
>> Flavio Hendry
>> TYDAC Inc. - http://www.tydac.ch
>> Web Mapping - http://www.mapserver.ch
>> Swiss Maps - http://www.mapplus.ch
>> ############ Mit freundlichen Gruessen / Kind Regards
>> ############ Flavio Hendry, CEO - mailto:flavio at tydac.ch
>> ############ TYDAC AG - http://www.tydac.ch
>> #### #### Geographic Information Solutions
>> #### #### Optingenstrasse 27 -- CH-3013 Bern
>> ############ Tel +41 (0)31 368 0180 - Fax +41 (0)31 368 1860
>> Location: http://www.mapplus.ch/adr/bern/optingenstrasse/27
