[mapserver-users] WCS reprojection issue
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Fri Jun 3 10:26:59 EDT 2011
Response_crs exists for letting user to select the output CRS. Have you tried it yet?
There are better possibilities for a success and especially for understanding what is really happening if you write WCS requests by hand and semd them with a browser instead of using a GIS client. Request examples at http://mapserver.org/ogc/wcs_server.html are good to start with.
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: Mark Phillips
Lähetetty: to 2.6.2011 22:16
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [mapserver-users] WCS reprojection issue
I'm struggling with an issue related to projections in a MapServer WCS
service. I've got a raster data file that is in EPSG:2163, and I'd like to
serve it via WCS in EPSG:4326. The only way I have managed to get this to
work is to reproject the data manually in advance and then reference the
ESPG:4326 copy of the data in my mapfile. When I do that, with the mapfile
below, the service seems to work beautifully. What I really want, though, is
to be able to leave my data in its original projection and have MapServer
reproject on the fly.
When I change the mapfile to use the original ESPG:2163 copy of the data,
and update the relevant projections in the mapfile from 4326 to 2163,
though, the service breaks, in the sense that the data shows up in (very
much) the wrong place. I first tried just changing the
projections commented in the mapfile below with ###LAYER_PROJECTION and
###LAYER_WCS_SRS from 4326 to 2163 (after changing the DATA line in the
layer to point to the EPSG:2163 copy of the data, of course), but that
didn't work. I then experimented with changing the ###SERVICE_WCS_SRS line
and/or the ###MAP_PROJECTION as well, but no luck.
What is especially confusing is that I *can* get this to work for a WMS
service. In the case of WMS, MapServer seems quite happy to serve EPSG:2163
data in ESPG:4326, as long as the ###LAYER_PROJECTION and ###LAYER_WCS_SRS
lines say EPSG:2163 (with "wcs" replaced by "wms", of course).
I'm sure that part of my problem is that I don't completely understand the
purpose served by each of the various projections specified in the mapfile.
Can someone offer some insight into what the correct approach is to getting
MapServer to reproject on the fly in a WCS?
In case it matters: I'm using MapServer 6.0, and am testing the WCS with
ArcMap 9.3.
Thanks!
--Mark
Here is my working mapfile for ESPG:4326:
MAP
NAME lucky
STATUS ON
SIZE 600 400
EXTENT -83.938 34.746 -81.340 36.361
IMAGECOLOR 255 255 255
WEB
METADATA
"ows_enable_request" "*"
"wcs_label" "My WCS Service"
"wcs_srs" "EPSG:4326" ###SERVICE_WCS_SRS
END
END
PROJECTION
"init=epsg:4326" ###MAP_PROJECTION
END
LAYER
NAME mylayer
TYPE RASTER
DUMP TRUE
STATUS OFF
DATA sampledata_wgs84/tif_wgs84.tif
INCLUDE "colormap.cmap"
PROJECTION
"init=epsg:4326" ###LAYER_PROJECTION
END
METADATA
"wcs_srs" "EPSG:4326" ###LAYER_WCS_SRS
"wcs_label" "My Layer"
"wcs_rangeset_name" "My Range"
"wcs_rangeset_label" "My Label"
END
END
END
