[mapserver-users] Re: ANGLE FOLLOW and Label Offset (v. 5.6.6)
uvg
mmypost at yandex.ru
Mon Jun 6 09:48:37 EDT 2011
Thank you, Thomas. Are there any workarounds for this problem? Is there 'best practices' for the problem? Maybe unvisible layer or other? 06.06.2011, 17:35, "thomas bonfort [via OSGeo.org]" <ml-node+6445146-1155722530-338610 at n2.nabble.com>: The status has not changed: label follow with offset is not supported. regards, thomas On Mon, Jun 6, 2011 at 15:33, uvg < [hidden email] > wrote: > Hi all! > Sorry for my bad English. > > I am trying to achieve is a label that follows the rivers that is also > OFFSET so that > the label does not 'above' on the line for the river. > > Sample code of mapfile: > > LABEL > COLOR 0 40 255 > FONT "arial-italic" > TYPE truetype > SIZE 7 > OFFSET 5 0 > ANGLE FOLLOW > POSITION LC > FORCE true > PARTIALS FALSE > > END > > "OFFSET" does not work. > How can I offset a label? > > I found a message posted for a long time: > http://osgeo-org.1803224.n2.nabble.com/label-FOLLOW-and-OFFSET-td2251280.html > > Maybe this problem is already solved? > > -- > View this message in context: http://osgeo-org.1803224.n2.nabble.com/ANGLE-FOLLOW-and-Label-Offset-v-5-6-6-tp6445138p6445138.html > Sent from the Mapserver - User mailing list archive at Nabble.com. > _______________________________________________ > mapserver-users mailing list > [hidden email] > http://lists.osgeo.org/mailman/listinfo/mapserver-users > _______________________________________________ mapserver-users mailing list [hidden email] http://lists.osgeo.org/mailman/listinfo/mapserver-users If you reply to this email, your message will be added to the discussion below: http://osgeo-org.1803224.n2.nabble.com/ANGLE-FOLLOW-and-Label-Offset-v-5-6-6-tp6445138p6445146.html To unsubscribe from ANGLE FOLLOW and Label Offset (v. 5.6.6), click here .
View this message in context: http://osgeo-org.1803224.n2.nabble.com/ANGLE-FOLLOW-and-Label-Offset-v-5-6-6-tp6445138p6445194.html
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110606/26090bd3/attachment.html
