[mapserver-users] Re: ANGLE FOLLOW and Label Offset (v. 5.6.6)
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Jun 6 10:02:34 EDT 2011
There was some recent discussion on the dev list about potentially using
the GEOMTRANSFORM to do something like a single sided offset then using
that to apply the label to. BUT I do not think that has been implemented
yet in mapserver.
Google for "mapserver geomtransform" also look at "geoprocessing" for
some other ideas.
Anyway, you might be able to do what you want if you:
1. import your data into PostGIS
2. create offset geometry in another table
3. export that table to a shapefile
4. then label that as an annotation layer so you do not draw the
geometry only the label and use the original data to draw the grometry
ie: two layers.
I have not tried this, but it might solve your problem.
-Steve W
On 6/6/2011 9:48 AM, uvg wrote:
> Thank you, Thomas.
> Are there any workarounds for this problem?
> Is there 'best practices' for the problem?
> Maybe unvisible layer or other?
> 06.06.2011, 17:35, "thomas bonfort [via OSGeo.org]" <[hidden email]
> </user/SendEmail.jtp?type=node&node=6445194&i=0>>:
> The status has not changed: label follow with offset is not supported.
> regards,
> thomas
> On Mon, Jun 6, 2011 at 15:33, uvg <[hidden email]> wrote:
> > Hi all!
> > Sorry for my bad English.
> > I am trying to achieve is a label that follows the rivers that is
> also
> > OFFSET so that
> > the label does not 'above' on the line for the river.
> > Sample code of mapfile:
> > LABEL
> > COLOR 0 40 255
> > FONT "arial-italic"
> > TYPE truetype
> > SIZE 7
> > OFFSET 5 0
> > ANGLE FOLLOW
> > POSITION LC
> > FORCE true
> > PARTIALS FALSE
> > END
> > "OFFSET" does not work.
> > How can I offset a label?
> > I found a message posted for a long time:
> > click here.
> View this message in context: Re: ANGLE FOLLOW and Label Offset (v.
> 5.6.6)
> <http://osgeo-org.1803224.n2.nabble.com/ANGLE-FOLLOW-and-Label-Offset-v-5-6-6-tp6445138p6445194.html>
> Sent from the Mapserver - User mailing list archive
> <http://osgeo-org.1803224.n2.nabble.com/Mapserver-User-f1969211.html> at
> Nabble.com.
> mapserver-users at lists.osgeo.org
