[mapserver-users] Problem using mapserver with WCS
Frank Warmerdam
warmerdam at pobox.com
Wed Jun 8 22:04:59 EDT 2011
On 11-06-08 07:54 PM, Virginia Maffei wrote:
> Hi, I installed ms4w and i'm trying to configure wcs in my mapfile, but it's
> not working. The url that i'm using is:
> http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example1-1.map&layer=localidades&mode=map&SERVICE=WCS&VERSION=1.0.0&REQUEST=GetCapabilities
> <http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example1-1.map&layer=localidades&mode=map&SERVICE=WCS&VERSION=1.0.0&REQUEST=GetCapabilities>
> but i cant see the xml it just stil shows the tiff image.
> I attached the mapfile so it can help to check which is the problem.
Virginia,
I suspect the mode=map is interfering - try dropping it out of the
request. It is not a proper WCS keyword.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
