[mapserver-users] Problem using mapserver with WCS
Virginia Maffei
vmaffei at gmail.com
Thu Jun 9 23:58:51 EDT 2011
Thanks Frank, i dropped the map= from the url but now it throws an error
that i dont understand:
msWCSGetCoverageMetadata(): WCS server error. Unable to determine the SRS
for this layer, no projection defined and no metadata available.
Do you have any idea whats the problem i'm having? the mapfile is the same
one.
Virginia
On Wed, Jun 8, 2011 at 11:04 PM, Frank Warmerdam <warmerdam at pobox.com>wrote:
> On 11-06-08 07:54 PM, Virginia Maffei wrote:
>> Hi, I installed ms4w and i'm trying to configure wcs in my mapfile, but
>> it's
>> not working. The url that i'm using is:
>> http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/tutorial/htdocs/example1-1.map&layer=localidades&mode=map&SERVICE=WCS&VERSION=1.0.0&REQUEST=GetCapabilities
>> but i cant see the xml it just stil shows the tiff image.
>> I attached the mapfile so it can help to check which is the problem.
> Virginia,
> I suspect the mode=map is interfering - try dropping it out of the
> request. It is not a proper WCS keyword.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110610/097820ec/attachment.html
