[mapserver-users] Problem using mapserver with WCS
Frank Warmerdam
warmerdam at pobox.com
Fri Jun 10 09:02:24 EDT 2011
On 11-06-09 11:58 PM, Virginia Maffei wrote:
> Thanks Frank, i dropped the map= from the url but now it throws an error that i
> dont understand:
> msWCSGetCoverageMetadata(): WCS server error. Unable to determine the SRS for
> this layer, no projection defined and no metadata available.
> Do you have any idea whats the problem i'm having? the mapfile is the same one.
Virginia,
I notice you do not have any PROJECTION blocks or SRS service metadata at
the layer or map level. I would suggest you re-review the WCS documentation.
You might want to use the following as an example of a fairly
minimalist WCS service mapfile (ignore all the request comments at
the start - these are part of the autotest).
http://svn.osgeo.org/mapserver/trunk/msautotest/wxs/wcs_simple.map
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
