[mapserver-users] Problem using mapserver with WCS
Virginia Maffei
vmaffei at gmail.com
Sat Jun 11 14:56:57 EDT 2011
Thank you Frank!
I looked at your mapfile and i noticed there were some configurations that
were missing.
Now its working!
regards,
Virginia
On Fri, Jun 10, 2011 at 10:02 AM, Frank Warmerdam <warmerdam at pobox.com>wrote:
> On 11-06-09 11:58 PM, Virginia Maffei wrote:
>> Thanks Frank, i dropped the map= from the url but now it throws an error
>> that i
>> dont understand:
>> msWCSGetCoverageMetadata(): WCS server error. Unable to determine the SRS
>> for
>> this layer, no projection defined and no metadata available.
>> Do you have any idea whats the problem i'm having? the mapfile is the same
>> one.
> Virginia,
> I notice you do not have any PROJECTION blocks or SRS service metadata at
> the layer or map level. I would suggest you re-review the WCS
> documentation.
> You might want to use the following as an example of a fairly
> minimalist WCS service mapfile (ignore all the request comments at
> the start - these are part of the autotest).
> http://svn.osgeo.org/mapserver/trunk/msautotest/wxs/wcs_simple.map
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110611/1d8c831e/attachment-0001.html
