[mapserver-users] Fwd: Tile of tiles with tif images
Fuchs Juan Carlos jfuch at indec.mecon.gov.ar
Thu Jun 9 12:04:36 EDT 2011
Hi Mark,
Our Goal is to get an image catalog
with auto zoom´s in a fast delivery via a web browser
with the tile aproach we deliver fast images with low resolution
and only the pertinent pieces in an higher resolution...
Thanks for asking, any ideas?
-JC
-----Mensaje original-----
De: Mark Korver [mailto:mwkorver at gmail.com]
Enviado el: Jueves, 09 de Junio de 2011 12:10 p.m.
Para: Juan Carlos Fuchs
CC: mapserver-users at lists.osgeo.org
Asunto: Re: [mapserver-users] Fwd: Tile of tiles with tif images
As Steve noted, if the input is TIF, then you prob want to be using
gdaltindex rather than tile4ms.
> Now we want to put them together (the Tiles),
>  say, first,  all the tiles from the images of the same province,
>  and later, all the tiles from the provinces of the same projection.
when  re-tile.py does it's work it knows nothing about what province
some TIF is in.  For you to be able to calculate all the tiles that
are in the .dbf that are in some province, and I assume you are
talking about the shapefile index produced when using retile.py, you
would need to do a spatial query against that dbf using some political
boundary polygon.
Still, I am not sure what the goal here is.  are you trying to re-tile
a set of TIFs to create a new group of tiles per province?
On Thu, Jun 9, 2011 at 9:47 AM, Juan Carlos Fuchs
<fuchs.juancarlos at gmail.com> wrote:
> Subject: Tile of tiles with tif images
> Dear Gentleman:
> Situation
> We have a collection of images tiled with re-tile.py.
> each record of our .dbf points to a diferent part of one tiff image.
> when we run tile4ms we get the following weird error
> Aborted. Unable to open
DBF:/home/jfuch/public_html/wms/Fase8/cbers-2b-cordoba-laborde-168-b-137-4-0
2-may-09-img-img-tif
> If we get things right, each record in our tile file point to a different
> part of one tiff image, but the shp file has an geometric extend for each
> image
> so, why didn´t this work??
> Is there an other way to get an accelerated access to very huge tiffs
file,
> sprengled over an big extension?
> Thanks in advance
> Cheers
> JC
> Juan Carlos Fuchs, arqto & mgtr.
