[mapserver-users] Fwd: Tile of tiles with tif images
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Jun 9 12:52:44 EDT 2011
Ok, I think there is a misunderstanding on how the commands work:
[set of shapefiles] -> tile4ms -> one shapefile with pointers to the set
[set of images] -> gdaltindex -> one shapefile with pointers to the set
What you are trying to do is:
multiple [sets of images] -> to multiple shapefiles
then concatentate your multiple shapefiles into a single index.
Mapserver does not support indexes of indexes of files. tile4ms does not
concatenate the files into a single file it creates a tileindex.
You can take your multiple tif tileindexes and create a tile index for
that and it can be used to display the bbox for each of the images by
specifying the LAYER TYPE POLYGON in the mapfile. BUT you can not use it
to display the TIF images.
If you want to create one large tileindex of all your TIF files the just
process them all through gdaltindex into a new tile index that contains
all the original images.
-Steve
On 6/9/2011 11:58 AM, Fuchs Juan Carlos wrote:
> Hi Steve,
> Yes, that´s the point!
> We are traying to tile a set of tiles that refer each to a diferent Tif
> image
> We first tile each image with re-tile.py
> we obtain a shp file with a dbf with field LOCATION pointing to a piece of
> the Tif image
> Next we use tile4ms to put those first tiles (shp´s) in a only one tile,
> obtaining a new shp
> why will this not work? after all, we are puting a group of shp´s in a tile.
> _JC
> -----Mensaje original-----
> De: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
> Enviado el: Jueves, 09 de Junio de 2011 11:47 a.m.
> Para: mapserver-users at lists.osgeo.org
> Asunto: Re: [mapserver-users] Fwd: Tile of tiles with tif images
> tile4ms only works with shapefiles as input.
> gdaltindex is probably what you want for TIF images.
> -Steve W
> On 6/9/2011 10:47 AM, Juan Carlos Fuchs wrote:
>> Subject: Tile of tiles with tif images
>> Dear Gentleman:
>> Situation
>> We have a collection of images tiled with re-tile.py.
>> each record of our .dbf points to a diferent part of one tiff image.
>> Now we want to put them together (the Tiles),
>> say, first, all the tiles from the images of the same province,
>> and later, all the tiles from the provinces of the same projection.
>> when we run tile4ms we get the following weird error
>> Aborted. Unable to open
> DBF:/home/jfuch/public_html/wms/Fase8/cbers-2b-cordoba-laborde-168-b-137-4-0
> 2-may-09-img-img-tif
>> If we get things right, each record in our tile file point to a
>> different part of one tiff image, but the shp file has an geometric
>> extend for each image
>> so, why didn´t this work??
>> Is there an other way to get an accelerated access to very huge tiffs
>> file, sprengled over an big extension?
>> Thanks in advance
>> Cheers
>> JC
>> Juan Carlos Fuchs, arqto& mgtr.
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
