[mapserver-users] Asking for guidelines about a project
Saka Royban
sakaroyban at yahoo.com
Fri Jun 17 01:52:01 EDT 2011
Thanks a lot brent
I checked provided link and i;m gonna give it a try.
About ur helpful advices, i'm confused about how to save data in PostGIS? with
what schema?
I mean i have to keep track of each paced point by moving objects. Should i
record each point as a record, so it means one table per moving object ?
Also for displaying these varaiant data, there should some sort of plan. I don't
think i'm able to say to MapServer CGI at each second connect to PostGIS and
read the new data, then i have to use MapScript. Am i right? (Can this process
be done via OpenLayers?)
Best Regards
To: Saka Royban <sakaroyban at yahoo.com>
Cc: MapServer <mapserver-users at lists.osgeo.org>
Sent: Tue, June 14, 2011 7:14:08 PM
Subject: Re: [mapserver-users] Asking for guidelines about a project
Saka,
I've had good success using PostGIS for data storage in implementing
tracking systems. While you'll need to create your own code for updating
the positions in the database, mapserver can read points from PostGIS and
can render the points into a map image for use with the OpenLayers client.
There are other solutions too, like OpenGTS
(http://opengts.sourceforge.net/index.html)
Best Regards, Brent Fraser
On 6/14/2011 12:08 AM, Saka Royban wrote:
Hi all.
>Strictly Speaking, i have a project that i should display some moving
>objects on a map via browser.
>Generally, i don't know how to start? i mean how should i save these
>time-based objects in DB and how to retrieve and display them via
>Mapserver? where should i use client side scripting like OpneLayers?
>Any help woudbe greatly appreciated.
>Thanks in advance
> _______________________________________________ mapserver-users mailing list
>http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110616/944f62e8/attachment.html
