[mapserver-users] PHP-Mapscript - clusterObj ?
Tamas Szekeres szekerest at gmail.com
Mon Jun 20 03:41:15 EDT 2011
Chris,
clusterObj should not be constructed from scratch, it is an existing member
of layerObj. Not sure how is that working in PHP, however.
Best regards,
Tamas
2011/6/20 Chris Green <chris.green at ibstv.co.uk>
> Hi list****
> I am running Mapserver 6.0 under Ubuntu 10.04 with PHP-Mapscript and I have
> been trying to get clustering to work with Mapscript. Actually it works fine
> when using a mapfile very similar to the ‘Clustering Railway Stations’
> example given in the 6.0 documentation if I use the mapfile to generate a
> WMS layer without Mapscript. However using the same mapfile I can’t get the
> clustered output to appear with Mapscript when I try the usual construction
> along the lines of:****
> $map = ms_newMapobj("/var/www/vhosts/mysite/httpdocs/test.map");****
> $layer1=$map->getLayerByName("test1");****
> $image=$map->draw();****
> $image_url=$image->saveWebImage();****
> This structure works on a non-clustered layer in the same mapfile. I can
> see in the documentation for MS RFC 69 that the idea is to use a new
> Mapscript object called clusterObj, but I can’t find any information on how
> to construct a clusterObj and several hours of trial and error yesterday
> didn’t get me very far. Can someone tell me how I should set up and use
> clusterObj?****
> Chris  ****
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110620/de32921b/attachment.html
