[mapserver-users] PHP-Mapscript - clusterObj ?
Chris Green
chris.green at ibstv.co.uk
Mon Jun 20 11:58:46 EDT 2011
Daniel
This works....
$map = ms_newMapobj("/var/www/vhosts/mysite/httpdocs/test.map");
$layer1=$map->getLayerByName("test1");
$layer1->cluster;
Thanks very much for the help!
Chris
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Daniel Morissette
Sent: 20 June 2011 15:26
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] PHP-Mapscript - clusterObj ?
On 11-06-20 10:22 AM, Daniel Morissette wrote:
> On 11-06-20 10:02 AM, Chris Green wrote:
>> Hi Tamas
>> Thanks for your comment. My first thought was that it should be
>> available from layerObj, and I spent quite a while trying variations
>> like:
>> $cluster1=$layer1->getClusterByName(“cluster1”);
>> But unfortunately I couldn’t make anything like that work. Anyone know
>> how this clusterObj works in php-Mapscript?
> AFAIK there is only one cluster object per layer, and according to the
> PHP MapScript source, you should be able to reach it as
> $layer1->cluster. The same methods as in SWIG MapScript seem to be
> implemented for the clusterObj in PHP MapScript. If that doesn't work
> then please let us know and we'll look deeper.
... and I see that clusterObj is documented in:
http://mapserver.org/mapscript/php/index.html#clusterobj
... and the ref to the clusterObj in the layerObj is listed in:
http://mapserver.org/mapscript/php/index.html#layerobj
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
