[mapserver-users] PHP-Mapscript - clusterObj ?
Daniel Morissette
dmorissette at mapgears.com
Mon Jun 20 10:26:27 EDT 2011
On 11-06-20 10:22 AM, Daniel Morissette wrote:
> On 11-06-20 10:02 AM, Chris Green wrote:
>> Hi Tamas
>> Thanks for your comment. My first thought was that it should be
>> available from layerObj, and I spent quite a while trying variations
>> like:
>> $map = ms_newMapobj("/var/www/vhosts/mysite/httpdocs/test.map");
>> $layer1=$map->getLayerByName("test1");
>> $cluster1=$layer1->getClusterByName(“cluster1”);
>> But unfortunately I couldn’t make anything like that work. Anyone know
>> how this clusterObj works in php-Mapscript?
> AFAIK there is only one cluster object per layer, and according to the
> PHP MapScript source, you should be able to reach it as
> $layer1->cluster. The same methods as in SWIG MapScript seem to be
> implemented for the clusterObj in PHP MapScript. If that doesn't work
> then please let us know and we'll look deeper.
... and I see that clusterObj is documented in:
http://mapserver.org/mapscript/php/index.html#clusterobj
... and the ref to the clusterObj in the layerObj is listed in:
http://mapserver.org/mapscript/php/index.html#layerobj
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
