[mapserver-users] Mapserver 6.0 regex
Chris Green
chris.green at ibstv.co.uk
Mon Jun 20 13:38:32 EDT 2011
I have one (hopefully the last!) problem with migrating from Mapserver 4.6
to 6.0, this time over the use of regex.
Using Mapscript on a Fedora platform I have been setting a filter in this
manner:
$map=newMapobj("/var/www/vhosts/mysite/httpdocs/test.map");
$layer1=$map->getLayerByName("test1");
$layer1->set("filteritem", "Attribute1");
$layer1->setFilter("/target/");
This worked fine, but not anymore. I see in the migration guide that a
regex should now be delineated as a string so I assume that "/target/"
should become "target". But that doesn't work either.
I am wondering if part of the problem is that as well as going from
Mapserver 4.6 to 5.0 I also changed from Fedora to Ubuntu 10.04, and I see
from the Mapserver documentation on Expressions that the OS may affect regex
operation.
Am I missing something obvious here? I am really tired of going in circles
over this.
Chris
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110620/13ece1d3/attachment-0001.html
