[mapserver-users] Problems installing MapScript on Mac OSx
William Kyngesburye
woklist at kyngchaos.com
Mon Jun 20 14:52:36 EDT 2011
First, the web server may need to be restarted, though the installer usually does this.
But it's probably PHP. PHP 5.3 now does not allow (by default) dl() loading of extensions, so your script that tries to dl('php_mapscript.so') will fail. It can be enabled, but I can't get this to work in my PHP package. So you need to add the extension to your php.ini. I just noticed that I missed this bit in my Mapserver installer, so you need to do it yourself.
Edit /usr/local/php5cgi/lib/php.ini and add this line (there is a "Dynamic Extensions" section, but it can go anywhere):
extension=php_mapscript.so
On Jun 20, 2011, at 11:25 AM, Ron Alt wrote:
> Hello: I am a beginner with Mapserver and would appreciate any help.
> I am having touble installing mapscript on a Mac osx 10.5 & 6.
> I have used the installers developed by William Kyngesburye at http://www.kyngchaos.com/software/mapserver.
> The installers have run sucessfully, but it appears as though Mapscript did not install.
> The mapserver cgi responds.
> The php server responds.
> However, when viewing the phpinfo(), there is not information displayed for mapscript.
> Also, I get an error when sending running a simple script [cannot find dl("php_mapscript.so");]
> Questions:
> Where are the mapscript files stored on OSx? (I cannot find them anywhere)
> Has anyone else encountered a similar problem with this build?
> Are there any other installers for Macs?
> note, I also tried his vers. 5.6.6-3 installer, but it would not work with the current UnixImageIO framework.
> Would appreciate any help.
> Thanks,
> Ron Alt
> FTA
> ron.alt at taxadmin.org
> mapserver-users at lists.osgeo.org
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
The equator is so long, it could encircle the earth completely once.
