[mapserver-users] PHP-Mapscript - clusterObj ?
Jeff McKenna jmckenna at gatewaygeomatics.com
Mon Jun 20 17:30:00 EDT 2011
Hi Chris,
Let's plan this for our next phase of attack.  As you travel down this
cluster-php-mapscript path, document your full examples in the MapServer
wiki:
- login to the wiki (use your osgeo ID, which you can create at
http://www.osgeo.org/osgeo_userid)
- goto http://trac.osgeo.org/mapserver/wiki/PHPMapScript
- create a new page there, in the "Examples" section
- add as many examples as you wish for the Cluster object
- be sure to add "this was added by [yourname] [email]"
- when you are satisfied with that, email the mapserver-dev mailing list
- then I will change the CLUSTER example in
http://www.mapserver.org/mapfile/cluster.html#php-mapscript-usage to
point to your page
And you get all the glory! :)
thanks!
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 11-06-20 4:47 PM, Chris Green wrote:
> Hi Jeff
> Thanks. Fame at last...!
> However I am still struggling with the combination of clustering and regex filtering. What I can say for sure is that clustering works if no regex filter is applied, and filtering works (using a regex filter in the form "/target/") with no clustering. But I have so far failed to make the two work together.
> This is where I am currently (which does not work for me):
> $map = ms_newMapobj("/var/www/vhosts/mysite/httpdocs/test.map");
> $layer1=$map->getLayerByName("test1");
> $layer1->cluster;
> $layer1->set("filteritem", "attribute 1");
> $layer1->setFilter("/target/");
> Any ideas?
> Chris
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Jeff McKenna
> Sent: 20 June 2011 20:31
> To: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] PHP-Mapscript - clusterObj ?
> Hi Chris,
> I've added your PHP MapScript example to the mapfile's CLUSTER page:
> Thanks!
> -jeff
