[mapserver-users] PHP-Mapscript - clusterObj ?
Chris Green
chris.green at ibstv.co.uk
Tue Jun 21 07:54:46 EDT 2011
Hi Jeff
I'd be happy to go down that path and document examples along the way as you suggest, but I have a feeling that there may be something about the way that the cluster algorithm works that makes it incompatible with the regex filtering that I would also like to do. If that turns out to be the case then I will need to restructure the way that I access my data, in effect to filter it myself before presenting it to the layer to be displayed with clustering. This will be quite a task - before I decide which way to go on this is there someone out there who can confirm (at least in principle) that it should be possible to simultaneously filter and cluster the data in a layer if I can only find the right mapscript syntax to make it happen?
Chris
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Jeff McKenna
Sent: 20 June 2011 22:30
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] PHP-Mapscript - clusterObj ?
Hi Chris,
Let's plan this for our next phase of attack. As you travel down this
cluster-php-mapscript path, document your full examples in the MapServer
wiki:
- login to the wiki (use your osgeo ID, which you can create at
http://www.osgeo.org/osgeo_userid)
- goto http://trac.osgeo.org/mapserver/wiki/PHPMapScript
- create a new page there, in the "Examples" section
- add as many examples as you wish for the Cluster object
- be sure to add "this was added by [yourname] [email]"
- when you are satisfied with that, email the mapserver-dev mailing list
- then I will change the CLUSTER example in
http://www.mapserver.org/mapfile/cluster.html#php-mapscript-usage to
point to your page
And you get all the glory! :)
thanks!
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 11-06-20 4:47 PM, Chris Green wrote:
> Hi Jeff
> Thanks. Fame at last...!
> However I am still struggling with the combination of clustering and regex filtering. What I can say for sure is that clustering works if no regex filter is applied, and filtering works (using a regex filter in the form "/target/") with no clustering. But I have so far failed to make the two work together.
> This is where I am currently (which does not work for me):
> $map = ms_newMapobj("/var/www/vhosts/mysite/httpdocs/test.map");
> $layer1=$map->getLayerByName("test1");
> $layer1->cluster;
> $layer1->set("filteritem", "attribute 1");
> $layer1->setFilter("/target/");
> Any ideas?
> Chris
> Sent: 20 June 2011 20:31
> Hi Chris,
> I've added your PHP MapScript example to the mapfile's CLUSTER page:
> Thanks!
> -jeff
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
