[mapserver-users] php-Mapscript and MySQL layer syntax
Chris Green
chris.green at ibstv.co.uk
Mon Jun 27 04:05:11 EDT 2011
Hi to all
I am using PHP5-Mapscript together with Mapserver 6.0 and I have a layer
which obtains its data from a MySQL database via an OGR connection. This all
works, but I am having trouble with two items of PHP-Mapscript syntax:
1. $layer->getExtent() - I can't make this work with my layer: can
someone confirm if it works with a MySQL layer and if so give a syntax
example?
2. $query= $layer->queryByAttributes(null, $expression, MS_MULTIPLE);
On the 2nd question I came across some advice from Frank Wamerdam dated 2006
which said:
"The trick with OGR connections to pass the filter through to OGR is to use
a query expression starting with WHERE. So you might do something like:
expr = 'WHERE ' + $qField + ' = ' + $qValue
$qLayer->queryByAttributes(null,$expr,MS_MULTIPLE);
(forgive my incorrect PHP syntax, I'm just trying to get the idea accross)."
However I can't come up with any expression that gives me any results at
all. Is there any current advice on how to do this kind of query over an OGR
connection?
Chris
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110627/319efefa/attachment-0001.html
