[mapserver-users] mapserver WMS
Daniel Morissette
dmorissette at mapgears.com
Mon Jun 27 09:54:25 EDT 2011
Which version of MapServer?
Line 47 in the map that you pasted is the end of the first layer
definition. Are you sure that you copied the right mapfile?
The error suggests an error loading a hashtable, which would be the
METADATA block just before the TYPE keyword (as if something was wrong
with your metadata block). Perhaps try removing the "##required" comment
in the metadata block. I'm not aware of any version of MapServer
suffering of this kind of problem with comments inside METADATA blocks,
but ya never know...
Oh wait... I think I found it... it must be a combination of the comment
at the end of the line, combined with incorrect line ends for your
platform... (Windows CRLF vs Linux/Unix CR) the result is that the "END"
delimiter of the metadata block is not seen (it's considered part of the
comment on the previous line) Removing the comments at the end of the
lines, or cleaning up the line breaks should fix the problem.
On 11-06-27 03:32 AM, Sila Khan wrote:
> i followed the same pattern of mapfile for accessing maps through wms
> and when i start it in browser it gives Error like this
> loadHashTable(): Unknown identifier. Parsing error near (TYPE):(line 47)
> when i modify the recommended line it goes to an other line with same Error
> plz help me to rectify the Error
> NAME "WMS-test"
> STATUS ON
> SIZE 400 300
> SYMBOLSET ../etc/symbols.sym
> EXTENT -2200000 -712631 3072800 3840000
> UNITS METERS
> SHAPEPATH "../data"
> IMAGECOLOR 255 255 255
> FONTSET ../etc/fonts.txt
> WEB
> IMAGEPATH "/ms4w/tmp/ms_tmp/"
> IMAGEURL "/ms_tmp/"
> METADATA
> "wms_title" "WMS Demo Server" ##required
> "wms_onlineresource" "http://yourpath/cgi-bin/mapserv.exe?" ##required
> "wms_srs" "EPSG:42304 EPSG:42101 EPSG:4269 EPSG:4326" ##recommended
> END
> END
> PROJECTION
> "init=epsg:42304" ##required
> END
> # Start of layer definitions
> LAYER
> NAME "park"
> METADATA
> "wms_title" "Parks" ##required
> END
> TYPE POLYGON
> STATUS OFF
> DATA park
> PROJECTION
> "init=epsg:42304" ##recommended
> END
> CLASS
> NAME "Parks"
> STYLE
> COLOR 200 255 0
> OUTLINECOLOR 120 120 120
> END
> END
> END # Layer
> LAYER
> NAME popplace
> METADATA
> "wms_title" "Cities" ##required
> END
> TYPE POINT
> STATUS ON
> DATA popplace
> PROJECTION
> END
> CLASS
> NAME "Cities"
> STYLE
> SYMBOL 2
> SIZE 8
> COLOR 0 0 0
> END
> END
> END # Layer
> END # Map File
> mapserver-users at lists.osgeo.org
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
