[mapserver-users] RE: Query-wrong results in IE8 if zoomsize is not
100%
Tipatino
tilo.keller at freenet.de
Wed Jun 29 15:11:40 EDT 2011
Hi David
thanks for the message, its just within a simple html page. However, the
same things happens for example with the airports in the well known ITASCA
example
(http://maps.dnr.state.mn.us/cgi-bin/mapserv54?img.x=332&img.y=130&mode=browse&layer=airports&zoomdir=0&zoomsize=2&imgxy=300.0+300.0&imgext=388201.781900+5200193.595290+500990.486520+5312982.299910&map=%2Fusr%2Flocal%2Fwww%2Fdocs_maps%2Fmapserver_demos%2Fworkshop-5.4%2Fitasca.map&root=%2Fmapserver_demos%2Fworkshop-5.4&savequery=true&program=%2Fcgi-bin%2Fmapserv54&map_web=+TEMPLATE+itasca_basic.html)
I would be curious to know if you can reproduce it ...
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Query-wrong-results-in-IE8-if-zoomsize-is-not-100-tp6530144p6530337.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
