[mapserver-users] RE: Query-wrong results in IE8 if zoomsize is
not 100%
Fawcett, David (MPCA)
david.fawcett at state.mn.us
Wed Jun 29 15:49:17 EDT 2011
I can reproduce it in both IE8 and FF3. Not sure what the issue is. I switched to the townships layer to make sure that it wasn't a tolerance issue in querying a point feature.
Obviously, they guy who built this page knows nothing about MapServer ; /
David.
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Tipatino
Sent: Wednesday, June 29, 2011 2:12 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] RE: Query-wrong results in IE8 if zoomsize is not 100%
Hi David
thanks for the message, its just within a simple html page. However, the
same things happens for example with the airports in the well known ITASCA
example
(http://maps.dnr.state.mn.us/cgi-bin/mapserv54?img.x=332&img.y=130&mode=browse&layer=airports&zoomdir=0&zoomsize=2&imgxy=300.0+300.0&imgext=388201.781900+5200193.595290+500990.486520+5312982.299910&map=%2Fusr%2Flocal%2Fwww%2Fdocs_maps%2Fmapserver_demos%2Fworkshop-5.4%2Fitasca.map&root=%2Fmapserver_demos%2Fworkshop-5.4&savequery=true&program=%2Fcgi-bin%2Fmapserv54&map_web=+TEMPLATE+itasca_basic.html)
I would be curious to know if you can reproduce it ...
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Query-wrong-results-in-IE8-if-zoomsize-is-not-100-tp6530144p6530337.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
