[mapserver-users] Re: EPSG:42304 -> EPSG:3978? or 3979?
Jeff McKenna jmckenna at gatewaygeomatics.com
Wed Jun 29 22:38:06 EDT 2011
Hello Joanne,
In my case I always use EPSG:3978 now for any of my applications which
previously used the custom 42304...no change to the data is needed.
PS. glad to hear that you are using it...I wish the Atlas maintainers
would also as well.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 11-06-29 6:54 PM, myOpenLayersUName wrote:
> Oh Jeff,
> It seems I'm always saying "no" to that question from you and then finding
> out later that I should have said "yes" but didn't realize it. So, first of
> all, thank you for continuing to respond to my questions even when I'm
> repeatedly too slow to follow something that's readily apparent to others.
> Unfortunately, in answer to your question this time, I'm going to go with
> "sort of."  You have confirmed my understanding of what happened, but I'm
> still not sure which of these two new EPSG codes I should be picking to
> update my own application and get away from using 42304.
> Can I just change the EPSG code to one or the other of the new ones (or
> either, since they seem to be the same as far as I can tell)? Or, do I have
> to reproject the data from the old 42304 to one of them before I can do
> this? When I compare the PROJ4 definitions of the new and old, they aren't
> the same and that suggests I need to reproject but someone told me that I
> should not have to do that... that I should be able to just change the code
> in my Mapfiles and OpenLayers WMS definitions.
> How do I proceed?
