[mapserver-users] MapServer securing .map files
Daniel Morissette dmorissette at mapgears.com
Mon Mar 7 09:35:18 EST 2011
MapServer has no built in support for securing data by users. If your
needs are not too complicated then it should be easy to implement
map-level security in your PHP and JavaScript application code. If you
have more advanced users/roles requirements then you may want to have a
look at http://geoprisma.org/
Actually, I see that geoprisma.org seems quite slow today. You could
also have a look at the following demo page which also includes a short
intro to GeoPrisma under the [About GeoPrisma] tab:
http://dev4g.mapgears.com/geoprisma/demo/
Daniel
On 11-03-06 06:06 AM, tigana.fluens at gmail.com wrote:
> What are the best practices when relating application data to MapServer
> data? If I have a database of users, and each user owns a specific map,
> what is the best way (also secure of course) of calling those maps (I'm
> assuming the .map files are the ones needed) that a specific user is
> related to? Given that:
> - Tom has map of his real estate
> - Mark has map of his farm
> - Web app is a PHP app that uses OpenLayers as an interface to call
> MapServer
> How do I manage restrictions, i.e. security?
> mapserver-users at lists.osgeo.org
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
