[mapserver-users] Problem with raster file and layer's getExtent method
Carlos Ruiz boolean10001 at yahoo.com
Mon May 9 13:16:44 EDT 2011
Hi list,
I'm using the getExtent method of layer object with PHP Mapscript, works fine with PostGIS layers but with a
raster files I get some troubles.
I have a DEM.IMG file, using gdalinfo -nomd dem.img throws this:
Driver: HFA/Erdas Imagine Images (.img)
Coordinate System is:
PROJCS["UTM Zone 13, Northern Hemisphere",
Corner Coordinates:
Upper Left  (  687178.570, 2247514.668) (103d12'26.04"W, 20d18'59.14"N)
Lower Left  (  687178.570, 2243914.668) (103d12'27.39"W, 20d17'2.08"N)
Upper Right (  690918.570, 2247514.668) (103d10'17.13"W, 20d18'57.80"N)
Lower Right (  690918.570, 2243914.668) (103d10'18.51"W, 20d17'0.75"N)
Center      (  689048.570, 2245714.668) (103d11'22.27"W, 20d17'59.94"N)
But $layer->getExtent() has the following extent:
-25000000, -25000000, 25000000, 25000000
Is there another way to get the raster file extent ?
Thanks in advance
IC Carlos Ruiz
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110509/8d4eab1e/attachment-0001.html
