[mapserver-users] Rendering line crossing iteslf
thomas bonfort thomas.bonfort at gmail.com
Wed May 11 06:13:58 EDT 2011
An undocumented and "not guaranteed to work in future versions" is to
trick mapserver in not drawing the cached base style for bridge lines.
As you are avoiding the line caching mechanism, you have to tweak the
linecaps for the base style.
CLASS
   EXPRESSION ([bridge]=1)
   STYLE
   END
   STYLE
      color black
      width 5
      linecap butt
   END
   STYLE
      color yellow
      width 3
      linecap round
   END
   STYLE
      color black
      width 1
   END
END
I haven't tested this recently, so please keep in touch if this solves
your problem or not.
regards,
thomas
On Wed, May 11, 2011 at 11:40, Niels-Peter Jensen <npj at i-gis.dk> wrote:
> Hi users
> We have a problem in rendering a route based on a line feature.
> When we use the common way to do that, by using two styles, with a thick
> black line that defines an outline, and a thinner defying the road center,
> we will not get the desired result.
> But I want to show where routes cross ("bridge" intersection), and not as a
> "normal" intersection, see the attached examples.
> As there is no outline definition on linefeatures I can't se how that can be
> done in a simple way.
> Niels-Peter
> I-GIS
> mapserver-users at lists.osgeo.org
