SV: [mapserver-users] Rendering line crossing iteslf
Niels-Peter Jensen
npj at i-gis.dk
Wed May 11 08:18:56 EDT 2011
Hi Thomas
The bridge was used as an anology. In fact, the line feature is a bus route
that crosses itself, and we just want to show where the route passes through
an intersection.
Niels-Peter
-----Oprindelig meddelelse-----
Fra: thomas bonfort [mailto:thomas.bonfort at gmail.com]
Sendt: 11. maj 2011 13:56
Til: Niels-Peter Jensen
Emne: Re: [mapserver-users] Rendering line crossing iteslf
On Wed, May 11, 2011 at 13:51, Niels-Peter Jensen <npj at i-gis.dk> wrote:
> Hi Thomas
> Thanks for the quick answer.
> We cannot make the style work in the mapfile and have to place it in
> the symbol file. By the way, we are using Mapserver 5.4.2.
> But anyway, I don't think it solves our problem.
> We don't have any "bridge" in our line data, it is just a single line
> feature that crosses itself.
then how can you distinguish the case of the bridge with the case of the
intersection ? applying the solution I proposed on all lines will give
incorrect cases everywhere you don't have a bridge, so it would not be a
possible solution.
thomas
> Regards
> Niels-Peter
> Sendt: 11. maj 2011 12:14
> Cc: mapserver-users at lists.osgeo.org
> An undocumented and "not guaranteed to work in future versions" is to
> trick mapserver in not drawing the cached base style for bridge lines.
> As you are avoiding the line caching mechanism, you have to tweak the
> linecaps for the base style.
> CLASS
> EXPRESSION ([bridge]=1)
> STYLE
> END
> STYLE
> color black
> width 5
> linecap butt
> END
> STYLE
> color yellow
> width 3
> linecap round
> END
> STYLE
> color black
> width 1
> END
> END
> I haven't tested this recently, so please keep in touch if this solves
> your problem or not.
> regards,
> thomas
> On Wed, May 11, 2011 at 11:40, Niels-Peter Jensen <npj at i-gis.dk>
> wrote:
>> Hi users
>> We have a problem in rendering a route based on a line feature.
>> When we use the common way to do that, by using two styles, with a
>> thick black line that defines an outline, and a thinner defying the
>> road center, we will not get the desired result.
>> But I want to show where routes cross ("bridge" intersection), and
>> not as a "normal" intersection, see the attached examples.
>> As there is no outline definition on linefeatures I can't se how that
>> can be done in a simple way.
>> Niels-Peter
>> I-GIS
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
